Launch ArcGis Field Maps from another Android App
1202
10-24-2023 01:11 PM
AndréBarsotti
Hello there,
I'm trying to launch ArcGis Field Maps from my Android App but it's not working (I keep getting the "Intent Not Found" exception), somebody had this issue before?
Below is a code sample of what I'm running:
package lab.openfieldmaps
import android.content.Intent
import android.os.Bundle
import androidx.activity.ComponentActivity
import androidx.activity.compose.setContent
import androidx.compose.foundation.layout.Column
import androidx.compose.foundation.layout.fillMaxSize
import androidx.compose.foundation.layout.fillMaxWidth
import androidx.compose.foundation.layout.padding
import androidx.compose.material3.Button
import androidx.compose.material3.MaterialTheme
import androidx.compose.material3.Surface
import androidx.compose.material3.Text
import androidx.compose.runtime.Composable
import androidx.compose.ui.Modifier
import androidx.compose.ui.platform.LocalContext
import androidx.compose.ui.unit.dp
import androidx.core.content.ContextCompat.startActivity
import lab.openfieldmaps.ui.theme.OpenFieldMapsTheme
class MainActivity : ComponentActivity() {
    override fun onCreate(savedInstanceState: Bundle?) {
        super.onCreate(savedInstanceState)
        setContent {
            OpenFieldMapsTheme {
                // A surface container using the 'background' color from the theme
                Surface(
                    modifier = Modifier.fillMaxSize(),
                    color = MaterialTheme.colorScheme.background
                    OpenFieldMapsButton()
@Composable
fun OpenFieldMapsButton(modifier: Modifier = Modifier) {
    val context = LocalContext.current
     val packageName = "com.esri.fieldmaps" // Replace with the package name of the target app
    val intent = Intent(Intent.ACTION_MAIN).apply {
        addCategory(Intent.CATEGORY_LAUNCHER)
        setPackage(packageName)
    Column(modifier = modifier.padding(12.dp)) {
        Button(
            onClick = {
                startActivity(
                    context,
                    intent,
                    null
            modifier = Modifier.fillMaxWidth()
            Text("Abrir Field Maps")
Tags (3)
AndréBarsotti
I found the solution, after some research. Below is the solution code:
import android.content.ComponentName
import android.content.pm.PackageManager
import android.util.Log
import android.widget.Toast
        setContent {
                Surface(
                    OpenFieldMapsButton(packageManager, Modifier)
@Composable
fun OpenFieldMapsButton(packageManager: PackageManager, modifier: Modifier = Modifier) {
        component = ComponentName(packageName, "$packageName.MainActivity")
    var isInstalled = false
    if (intent.resolveActivity(packageManager) != null) {
        Toast.makeText(context, "Applicação localizada...", Toast.LENGTH_LONG).show()
        isInstalled = true
        Button(
            onClick = {
                try {
                    startActivity(
                        context,
                        intent,
                        null
                catch (e: Exception) {
                    Toast.makeText(context, "ERROR: ${e.message}", Toast.LENGTH_LONG).show()
                    Log.e(MainActivity::class.java.simpleName, "Houve um erro ao tentar executar a aplicação: ${e.message}", e)
            modifier = Modifier.fillMaxWidth(),
            enabled = isInstalled
