JSAPI toggle field visibility in Popup based on field value?
2921
04-27-2015 10:18 AM
JosephWallis
I have a dataset with a lot of missing attribution.  As opposed to presenting the user with a popup that shows a bunch of empty values I'd like to toggle the visibility based on whether the particular field has a value.  so for instance for a given fieldname definition:
{fieldname: "DPTH_M", label: "Depth (meters): ", visible: true },
if DPTH_M was empty I would not want to display this in the popup.  Can visibility be toggled true or false based on this requirement?
KellyHutchins
Esri Notable Contributor
No not using the popup template but you can define a function that will be used to render the popup content. In the function you could then check for the presence of a value and add it to the popup.  Here's a link to an older sample that shows how this works:
Info window with chart | ArcGIS API for JavaScript
