ITopologicalOperator.Difference
2499
11-29-2017 01:17 AM
HagenProbsthain1
Does anyone have some experience with ITopologicalOperator:Difference?
I want to erase features or feature parts (points, multipoints, lines or polygons) inside the polygons of a polygon featureclass.
I'm looking for an example how to use it. I always get an error when calling the method:
NotImplementedException
I know, in the helptext is written: "This method does not support GeometryBags."
But it works for ConstructUnion in the same manner, so I think that's not the problem.
(infeatclass is type of multipoint, erasefeatclass is type of polygon)
Friend Function funcEraseTest(pInFClass As IFeatureClass, _pEraseFClass As IFeatureClass) As IGeometry
        ' put all geometries to be erased into a collection
        Dim pPointSearchCur As IFeatureCursor = pInFClass.Search(Nothing, False)
        Dim pPointGeomBag As IGeometryBag = New GeometryBag
        Dim pPointGeomColl As IGeometryCollection = pPointGeomBag
        Dim pSimplify As ITopologicalOperator2
        Dim pFeat As IFeature
        pFeat = pPointSearchCur.NextFeature
        Do While Not pFeat Is Nothing
            pSimplify = pFeat.ShapeCopy
            pSimplify.IsKnownSimple_2 = False
            pSimplify.Simplify()
            pPointGeomColl.AddGeometry(pSimplify)
        Loop
        ' put all erase geometries (polys) into a collection
        Dim pPolySearchCur = pEraseFClass.Search(Nothing, False)
        Dim pEraseGeomBag As IGeometryBag = New GeometryBag
        Dim pEraseGeomColl As IGeometryCollection = pEraseGeomBag
        Dim pEraseSimplify As ITopologicalOperator2
        pFeat = pPolySearchCur.NextFeature
            pEraseSimplify = pFeat.ShapeCopy
            pEraseSimplify.IsKnownSimple_2 = False
            pEraseSimplify.Simplify()
            pEraseGeomColl.AddGeometry(pEraseSimplify)
        Loop
        ' make erase
        Dim pResultMultiPoint As IMultipoint
        Dim pTopoOp As ITopologicalOperator
        pTopoOp = pPointGeomColl
        ' THIS THROWS THE ERROR:
        pResultMultiPoint = pTopoOp.Difference(pEraseGeomColl)
        Return pResultMultiPoint
    End Function
AbhishekKabra
GeometryBag does not implement all the methods from ITopologicalOperator interface. BufferClip, and Simplify are the only methods of ITopologicalOperator supported on GeometryBags.
I think you can do it like this:
For each multipoint in multipoint_feature_class
   For each polygon in polygon_feature_class
      // C++ syntax
      IGeometryPtr ipRes;
      ITopologicalOperatorPtr(multipoint )->Difference(polygon, &ipRes);
      Add ipRes to result geometry bag
   end
end
HagenProbsthain1
OK, thank you for your response, I'll try to test it. In the meantime I've called the Toolbox-Tool "Erase" inside my code. It is easier to use as to call the method in loops.
HagenProbsthain1
The problem is, that the documentation says for most of the methods: "This method does not support GeometryBags". But this is not correct, i. e. ConstructUnion works with it. So I thought, the sentence is obsolete and it was forgotten to delete. But at least for the Difference method the documentation is correct.
Therefore my workaround is to use the ConstructUnion method to create a multipart geometry for both input and erase features and then put these geometries to the Difference method. It works fine.
