importing UTF-8 shapefiles into feature class
9910
10
03-17-2016 09:40 AM
JonathanMcCloskey1
Hi All
I have been looking for a solution to import Arabic characters with UTF-8 encoding in my shapefiles to my GDB as feature classes, but I lose most of the text.
Does anyone have a solution?  looking everywhere
Thanks
Jon
AdrianWelsh
MVP Honored Contributor
Hi Jonathan,
Take a look at the following stack exchange site. There are some step by step instructions that may help get you what you need:
convert - Character encoding support in geodatabases and shapefiles - Geographic Information Systems...
JonathanMcCloskey1
no tried it all regedit update to default UTF-8.   the problem is that the shapefile has been created from a postgis database.  Open Street Map (OSM) data and if I take into QGIS (the shapefile) I can then import it into and ESRI feature class and I have the text as normal.
I would like to update the shapefile, so that it reads the correct characters
DanPatterson_Retired
Jonathan
Is this the article you are referring to
21106 - Read and write shapefile and dBASE files encoded in various code pages
and was a *.cpg file created in the database ? if so, was it incorrect?  can you create a correctly encoded one in ArcMap?  They can be created in a text editor if they are missing, but I haven't access to one with an alternate encoding than utf-8
JonathanMcCloskey1
Hi Dan,
Yes I have been using this article and haven't had any success, also created the .cpg file using a text editor and still no joy.
If I take it into a QGIS and save as shapefile with UTF-8 is works.   I can send you a shapefile that I have issues with, and see if you have a solution.  [email protected]
Thanks
Jon
it would be worthwhile selecting a few rows and exporting to a shapefile (so it isn't too big) then zip and attach it to a post so other can have a look as well.  Remember to do this from the thread itself so that the attach option in the bottom right of the post appears.  If you do it from within the 'mail' section, attach isn't there
JonathanMcCloskey1
JonathanMcCloskey1
thanks for the suggestion
HernandezAstorga
Hi everyone!!
I have a little big problem , I have  a file "File CPG (.cpg)",I try to open this in my ARCGIS10 but not let me "Invalid raster dataset. Failed to create raster layer". Any suggestions for open this file? My email is [email protected]
Thank you
RebeccaStrauch__GISP
Hernandaz,
Posting this at the end of every post does not help get an answer to your question.  You should post  one (1) NEW question in the Imagery and Remote Sensing​ site and remove all your other posts.
Thanks.
