Import Attributes to Point from Underlying Polygon - Automation
2114
09-09-2019 12:53 PM
TonyHerhold1
I'm having a hard time with what should be a super simple process.
When adding points to a pre-existing feature class, I need to populate an already-existing field in that feature class with data from an intersecting polygon feature class.
Attribute Assistant has this function ("Intersecting Feature"), and it works great, but I need to be working in Pro. There doesn't seem to be a solution using Attribute Rules that replicates it.
Also, I do not want to export a new point feature class. I need to update the attributes of an existing points file on-the-fly (as new points are digitized, attribute info from the underlying polygon feature class automatically populates the point feature class field).
The values in the polygon feature class will all be unique numeric values.
I am open to scripting solutions, but I have never written Python code before.
Tony
MichaelVolz
Esteemed Contributor
What type of data source are your working with (file gdb, SDE)?  I think Attribute Rules might now be available with file gdbs but it's functionality is definitely not equivalent to Attribute Assistant.
TonyHerhold1
For now, I'm working in a file gdb.
TINATHOMPSON
Were you ever able to find a solution?  I have this same issue, only difference is that I'm using an Enterprise Geodatabase.
