How to use a polyfill when creating custom widget
1298
05-18-2020 04:15 PM
NathanB
At the risk of getting yelled at or standing in a corner with a dunce cap while people point an yell 'noob'.....i recently worked on a custom widget.  however, there are a lot of template strings in there.  however, IE 11 doesn't support template strings.  either i have to go back and remove every back tick or i can try to use a polyfill.
for example, i'd like to use:
<script src="https://cdnjs.cloudflare.com/ajax/libs/babel-polyfill/6.26.0/polyfill.min.js"/>
i'm not sure where to place it within the widget project.  does it go in the html file, etc.  i think i may have saw something similar in the doc but i don't remember.  thanks in advance
HarishPalaniappan
Adding polyfill to the resources array within your Web App Builder App.
An example here:
https://github.com/agrc/wfrc-wab-widgets
Details: https://gis.utah.gov/best-practices-for-building-web-appbuilder-widgets/
Or if you want to add custom libraries to a widget then add reference in the widget.js file.
An example here-
https://stackoverflow.com/questions/56567563/adding-custom-libraries-to-a-widget-in-arcgis-web-appab...
polyfill‌ #ajax#esri js 4.12
