How to limit the analysis layer into the CreateDriveTimeAreas widget
1150
02-24-2017 08:37 AM
SimoneGadenz1
Hello!
I am looking for the right way to limit the layers that are shown into layer list into the CreateDriveTimeArea widget generated by the WAB. I read here [1] that there is a property of the
esri/dijit/analysis/CreateDriveTimeAreas
called  showSelectAnalysisLayer that should do the job. I modified the config_Analysis.json file into the widget/analysis folder to include the parameter, but there is no change in the behavior of the widget.
Is that property relevant for my need? Is there a known procedure to make only one layer available for analysis?
Thank you.
Simone
[1] CreateDriveTimeAreas | API Reference | ArcGIS API for JavaScript 3.19
