How to implement derived output parameter for ApplySymbologyFromLayer()
1612
12-18-2023 09:54 AM
cweirpatrickco
I'm trying to set feature symbology's from .lyrx files in a python script tool but am running into issues. The code runs with no errors but the .lyrx symbologies aren't applied (ie the symbologies don't change after script completion). I've opened a case with ESRI support, but it hasn't been much help. On the tool documentation page it says...
To see the symbology created in a script tool, the tool must include the layer as a derived output parameter. Similarly, the Updated Input Layer parameter value must be added as a derived model parameter model tool to see the symbology changes.”
How can I successfully implement that into this code? I tried in Line 32 but had no luck.
def apply_lyrx(map_object, lyrx_folder):
    Applys .lyrx files to layers in the TOC according to layer name
    Parameters:
    - map_object (arcpy.mp.ArcGISProject("").activeMap): Map object
    - lyrx_folder (path): path to .lyrx source folder
    Returns:
    None
    # Loop through layers in the TOC
    for lyr in map_object.listLayers():
        if "primary" in lyr.name.lower():
            lyrx_file = "Primary.lyrx"
        elif "secondary" in lyr.name.lower():
            lyrx_file = "Secondary.lyrx"
        elif "pole" in lyr.name.lower() and "anno" not in lyr.name.lower():
            lyrx_file = "Pole.lyrx"
        elif "anno" in lyr.name.lower():
            lyrx_file = "Pole_Anno.lyrx"
        else:
            lyrx_file = "clip_poly.lyrx"
        symb_path = os.path.join(lyrx_folder, lyrx_file)
        # apply .lyrx file
        if lyr.isFeatureLayer:
            arcpy.ApplySymbologyFromLayer_management(lyr, symb_path)
            # Set layer as derived output parameter
            arcpy.SetParameterAsText(0, lyr)
            arcpy.AddMessage(f"'{lyrx_file}' applied to '{lyr}'")
        else:
            arcpy.AddMessage(f"'{lyr.name}' is not a feature layer...")
    arcpy.AddMessage("All .lyrx files applied...")
    aprx.save()
PS: see attached .txt file for a stand-alone version of this code that works when run in the python window (symbologies get updated)... so I know it's something when running ApplySymbologyFromLayer() in a script tool.
cpehlke
I've run into this same problem before.
What worked for me was not using:
ApplySymbololgyFromLayer()
but instead using:
SetParameterSymbology()
https://pro.arcgis.com/en/pro-app/latest/arcpy/functions/setparametersymbology.htm
