How to find Max value among Fields
21570
8
03-13-2017 09:32 AM
StephenCoppola
Good Day GeoNet Community,
Would like to inquire how to search among rows of a table and find the maximum value only using a selected set of fields.  For example, If the table consists of five columns ID,F1,F2,F3,F4, would want to search and find the maximum value in F2 and F4.  The maximum value would become an value in a new field, called MX.  An arcpy solution is optimal and generic case is best.
Your suggestions are much appreciated, thank you for your time.
Example Table ("MyVals")
IDF1F2F3F4MX
11221333
232655
369566
4778877
599988
6477199
822441233
975331
109452
DarrenWiens2
MVP Alum
If you want the max of F2 and F4, in field calculator:
max(!F2!,!F4!)
Or updateCursor (untested):
with arcpy.da.UpdateCursor(fc,['F2','F4','MX']) as cursor:
  for row in cursor:
    row[2] = max(row[0],row[1])
    cursor.updateRow(row)
DarrenWiens2
MVP Alum
max(!F2!,!F4!)
  for row in cursor:
TokiLee
Hi Darren,
If I have 300 fields, if there a way to loop through all fields to find the max without list all fields manually?
Thank you!
RosialineMarques_Roedel
Hi
I'm trying to apply max function but it's not working...any relation with properties??? string value?
Waffle_House
I agree this doesn't seem to work and therefore should not be marked as the solution. @DarrenWiens2
This thread seems to agree: https://gis.stackexchange.com/questions/90697/how-to-populate-new-field-using-expression-containing-...
DarrenWiens2
MVP Alum
What doesn't work? Quick test seems successful:
Screen Shot 2021-03-09 at 5.00.36 PM.pngScreen Shot 2021-03-09 at 5.00.36 PM.png
DarrenWiens2
MVP Alum
 Python cursor solution is successful, too:
Screen Shot 2021-03-09 at 5.08.12 PM.pngScreen Shot 2021-03-09 at 5.08.12 PM.png
KedaravindanBhaskar
Hello Stephen,
I faced a similar issue. The following code worked for me -
Max($Field1,$Field2)
Expression type - Arcade.
Regards, Kedar
Bud
Legendary Contributor
