How to change .soe file name using maven pom.xml
1073
09-01-2023 11:13 AM
IakovMelnikov
I've created an SOI. Maven "install" goal creates .soe file (MySOI.soe). Is there a way to modify .soe file name ( i.e. append version number) in pom.xml so that the name MySOI.soe becomes MySOIv1.0.soe?
Here is an extract from pom.xml:
<plugin>
    <groupId>com.esri.arcgis.enterprise.sdk</groupId>
    <artifactId>sdk-plugin</artifactId>
    <version>10.9.1</version>
    <dependencies>
        <!-- Include any additional plugin dependencies here if needed -->
    </dependencies>
    <configuration>
        <configProp>
            <Version>1.0</Version>
            <Author>AuthorName</Author>
            <Company>CompanyName</Company>
            <TARGETS>10.9</TARGETS> <!-- Required -->
        </configProp>
    </configuration>
    <executions>
        <execution>
            <id>package-soe-goal</id>
            <phase>package</phase>
            <goals>
                <goal>package-soe</goal>
            </goals>
        </execution>
    </executions>
</plugin>
Amir-Sarrafzadeh-Arasi
Dear IakovMelnikov,
I hope you are doing well,
If you want to change the name of the .soe file you should change the value inside "artifactId".
For example you should do that: <artifactId>MySOIv1.0</artifactId>.
After changing the value you should reload project from the .pom file.
If you need more clarification please let me know.
Sincerely yours,
Amir Sarrafzadeh Arasi
