How to autogenerate a workspace and base name for output parameter in Python script tool?
3999
08-06-2014 04:01 AM
MarAlcaraz
As all geoprocessing tools do, I would like my Python script tool to generate automatically the workspace and base name for outputs.
In ArcGIS Help online, "Understanding validation in script tools" says about internal validation that:
  • Generate a default catalog path for output datasets.
After reading carefully (maybe not enough) the "Customizing tool behavior in a Python toolbox" from ArcGIS Help, I have not been able to adapt my script .
I have modified the Validation Class adding the getParameterInfo method, with the following code:
def getParameterInfo(self):
    # Input raster
    param0 = arcpy.Parameter(displayName="Introduce Piezometry raster dataset:",
                                                  name="piezoras",
                                                  datatype="GPRasterLayer",
                                                  parameterType="Required",
                                                  direction="Input")
    # Output raster
    param1 = arcpy.Parameter(displayName="Define output Groundwater Flow Direction raster dataset:",
                                                   name="direcras",
                                                  datatype="DERasterDataset",
                                                  direction="Output")
    param1.parameterDependencies = [param0.name]
    param1.schema.clone = True
    params = [param0, param1]
    return params
Some doubts:
  1. The definitions for these parameters in Parameters Tab do not change, why? The code in Validation Tab is not related to Parameters Tab???
  2. How can I related them? With the displayName property? Where is the name property in Parameters Tab?
  3. In general, How to autogenerate a workspace and base name for output parameter in Python script tool in dialog tool window?
Thanks in advance
