How to add a marker(point graphic) on map by using the result of identify operation performed on a map service resource
3734
11-03-2015 10:21 PM
aashumittal
Please Help!!
Is there any way to show a point on map by passing identify parameters thru identify operation on map service.
This is  the result i am getting on performing operation and wants to show point on map.
http://gismp.nic.in:8399/arcgis/rest/services/GeoApproachv3/MapServer/identify?geometry=77.424179055...
Thank you!
RobertScheitlin__GISP
aashu,
    You should use the Flex API Identify task and parameter objects and then an async result handler function to add the result to the map.  See the Flex API docs and samples
ArcGIS API for Flex 3.7
Identify features—ArcGIS API for Flex | ArcGIS for Developers
