How do you fix the "Unsupported Pixel Type" error when running the Flow Direction tool while using "MFD" as your flow direction type?
5283
5
02-28-2018 10:27 AM
BradenAnderson1
Here are all the messages that I got from my execution of Flow Direction, trying to use the new Multi Flow Direction algorithm in ArcGIS 10.6.
Executing: FlowDirection C:\Users\A02150284\Documents\GISData\NewBRATFile\01_Inputs\04_Topo\DEM_1\Filled_DEM.tif C:\Users\A02150284\Documents\GISData\NewBRATFile\01_Inputs\04_Topo\DEM_1\Flow\FlowDir.tif NORMAL # MFD
Start Time: Wed Feb 28 11:22:03 2018
ERROR 999999: Error executing function.
Unsupported pixel type
Failed to execute (FlowDirection).
Failed at Wed Feb 28 11:22:03 2018 (Elapsed Time: 0.05 seconds)
I've ran the tool on multiple DEMs, and none have worked. The only tool I've run on the DEM before this is running Fill on it. I haven't seen anyone else have a problem with it, though that makes sense given how new it is. If anyone has advice for how to fix this, I'd appreciate it.
DanPatterson_Retired
Multi Flow Direction so it is a cloud raster format?  Any details like the folder name the file name?
The MFD flow direction type only supports creation of output flow direction raster in Cloud Raster Format (CRF), such as, flowdir1.crf, within a folder workspace.
BradenAnderson1
I must have missed that when I was reading the documentation, now I feel foolish. Changing my output from a .tif to a .crf fixed my problem, thank you!
I was wondering since you marked the question 'Assumed as Answered' and I didn't know if it was you that did it or someone else, so I had no clue if that was the solution to the problem or not.
JenniferGillespie2
I am getting the same error when attempting to get MFD from Flow Direction. I attempted to specify the output raster as a .crf format and am still getting the error. Is there something else that I am doing wrong?
RAJNEESHSHARMA
I was getting the same error even after changing the name to flowdir.crf. I got it resolved by changing the output directory folder. Seems like the .crf file cannot be saved in the geodatabase folder; it has to be a simple folder.
