How do I create multiline labels using Arcade functions?
27609
19
02-15-2017 06:10 AM
MaryAnnSteinmetz
I'm trying to label polygons using two separate fields. I would like this to show on two separate lines. In desktop I use the vbnewline command. Is there an equivalent in Arcade?
WendyHarrison
Hi MaryAnn,
You can use TextFormatting.NewLine
The text constants are found here: Types | ArcGIS for Developers
thanks
Wendy
NatalieMatthews
Hey Wendy, TextFormatting.NewLine works for me in Pro, but not in AGOL. I've tried Chrome and Firefox. Do you know if this should work?
 "1" + TextFormatting.NewLine + "2"
Thanks!
WendyHarrison
Hi Natalie - it doesn't work in AGOL - it's a known issue at this point.
hope all is well!
wendy
NatalieMatthews
Thanks Wendy!
AhnaMiller2
Have we heard anything more if this has since become supported in AGOL?
by Anonymous User
Not applicable
Any news on this?
DanPatterson_Retired
from the help... so I guess not, unless the help is out of date
Constants | ArcGIS for Developers
Inserts a new line, or line break, into the text. Multi-line labels are NOT supported in the ArcGIS API 3.x for JavaScript nor in the ArcGIS Online map viewer.
Example
Returns "T2N R1W"
"T" + $feature.TOWNSHIP + TextFormatting.NewLine + "R" + $feature.RANGE
by Anonymous User
Not applicable
Unfortunately, this doesn't work.
That's what I said... it doesn't work.  read the help snippet I posted
