how can i export data to personal geodatabase
3291
8
12-26-2017 10:03 PM
MunaAlajmi
hello
Im GIS developer i want some one to help me in writing code in VB.NET   to  export an sde feature class to personal geodatabase
i have a layer in arcmap that come from sdedatabase i want to export it to personal geodatabase
Thanks
MMGIS
DanPatterson_Retired
What version of ArcMap and arcsde, in case it matters, since personal geodatabases indicate older versions
XanderBakker
Esri Esteemed Contributor
Is it really necessary to export to a Personal Geodatabase (.mdb)? This format is really old and Esri recommends to move towards the File Geodatabase. I did find a "museum piece" of code based on VB6 that shows how to do this conversion. I'm sure you can port it to VB.Net: Copying a feature dataset from an ArcSDE geodatabase to a personal geodatabase
TedKowal
Honored Contributor
File Geodatabase is not compatible with anything outside of ESRI!  A Personal Geodatabase can be read from almost any other application.
Please vote on keeping this option within Pro  https://community.esri.com/ideas/12662
MunaAlajmi
hello thanks a lot for your help
not it not necessary to personal....  it  is OK even to export to file geodatabase
MunaAlajmi
ArcMap  10.3.1
sde 10.3.1
The question becomes, why are you having to use vb.net for older software, when there are builtin tools within the arc* suite that don't require any coding what-so-ever.  Perhaps you can elaborate on why your focus is so limiting
MunaAlajmi
Because i was developing add Inn application with certain tools and commands  over arcmap and i want to develop add inn command in my toolbar that will help end user to export a layer to personal geodatabase or file geodatabase so user can use it in his work .. actually the end user are not  a gis user who know how to work with  ArcMap they want to click button to export map without  any interaction from their side
ModyBuchbinder
Hi
If you need to write a code for ArcMap you should open a post in the ArcObjects community.
In ArcObjects code you can call any GP tool easily, this is the best way in most cases.
here: arcobjects-sdk-community-samples/Net/Geoprocessing/GPGeodatabaseConversion at master · Esri/arcobjec...  you can find an example of using GP tools for conversion of data. I think it is almost what you need.
Have Fun
Mody
