I try to calculate de mean of Z coordinates of my polylines using Arcade expression. I use the expression below on a feature layer of Polylines (with not null Z coordinates) but the Z values of each vertices returned by the Arcade expression is always "null". The "IsEmpty" console message return "true" for each vertices. Is there a way to get the Z coordinates with the "calculate field" Arcade profile ?
var myPaths = Geometry($feature).paths;
var points_Z = [];
for (var i=0;i<Count(myPaths);i++){
var myPath = myPaths;
for (var j=0;j<Count(myPath);j++){
Console(IsEmpty(myPath
points_Z[Count(points_Z)] = myPath
return Mean(points_Z);
Regards,
Gaëtan Lavenu
Esri France
I think the Z values get stripped off when you publish the layer. I just published a polyline 3D based on the sample here: https://community.esri.com/people/xander_bakker/blog/2016/07/08/working-with-3d-and-m-aware-geometri... and when I publish the layer to ArcGIS Online and consult the layer through the REST API I notice that it does have the property Z enabled, but doing a query returns a geometry without Z values. In addition when you do a "Text($feature)" in the Arcade window you will see that the geometry does not have any Z values:
Hi Xander,
Thank you for your answer. I have the same issue. When I query the Rest API the feature layer has z enabled but when using Arcade with the "Text($feature)" instruction, Z values are not returned in the paths arrays. I don't know why ?
Kelly Gerrow, Can you confirm this behavior? Is there a way to use Arcade in ArcGIS Online and have access to the 3D properties of a geometry?
