Help With Spatial Views in Oracle
8032
13
06-17-2015 03:13 PM
DavidYamamoto
Hello Kind People. I'm trying to create a database view in Oracle, joining polygon feature class in the geodatabase to an attribute table. I'm using the ArcCatalog tool Data Management Tools --> General --> Create Database View. I specify all of the input parameters, including the SQL to define the view. I'm including the OBJECTID and SHAPE field from the feature class. The tool runs fine, but when I look at the view in Catalog, it's just a data table. The SHAPE column is of type LONG. I thought I should be able to load the view up in ArcMap and see the geometries. Am I misssing something here? Than you very much in advance for any and all assistance. David
DavidYamamoto
Hi Sam. Okay, will do. By the way, is there a special license level for the Data Management-->Database toolset? I don't see it in Catalog.
DavidYamamoto
I found it! It's different in 10.3
Data Management-->Geodatabase Administrattion-->Mirgrate Storage
Sorry about that.
DavidYamamoto
Hi Sam. I used the Migrate Storage tool to change the geometry storage type, created the view, AND IT WORKED! You've been very helpful. I can't thank you enough. David
SamuelTompsett
You are very welcome. Please mark this thread as answered.
Have a good day!
-Sam
