Help on xlsform syntax
823
06-30-2017 03:49 AM
SamuelNyarko
I am undertaking tree inventory with GeoODK.
After measuring the diameter of alive  trees (not less than 30 trees) in a plot, I need to measure only the height of the tress with the MAXIMUM, MINIMUM and MEDIUM diameters.
In an instance where the total trees are even number say 30, then the corresponding medium trees for  medium measurement will be for 2 trees.
I need a guide for a formula that will help me answer questions such as
What is the height of the MAXIMUM  Diameter tree?
What is the height of the MINIMUM  Diameter tree?
What is or are the heights of the MEDIUM  Diameter trees?
