Esri Live Traffic Link
2584
02-07-2024 01:27 PM
AJThomas1212
Hello,  I have been tasked with adding a live traffic map layer to our esri map app.
Does anyone know:
If a live traffic link I can use exists?
How to get started with esri live traffic?
Thanks in advance!
~AJ
DerekLaw
Esri Esteemed Contributor
Hi @AJThomas1212,
Please take a look at this item, World Traffic Service
Hope this helps,
AJThomas1212
Thanks, I saw that link.  It doesn't seem to be working anymore.
Bud
Legendary Contributor
AGOL idea: Update the World Traffic Service for the new map viewer
The link works for me as long as I click Open in Map Viewer Classic.
DerekLaw
Hi @AJThomas1212  and @Bud,
The Live Traffic service is working for me in the New AGOL Map Viewer fine.
I'm unsure what issue(s) you're encountering.
Hope this helps,
John-Foster
@AJThomas1212You can use the traffic service in your app, it is a subscriber service, you are required to provide an authentication token when requesting the service. When you visit the item description page in Living Atlas as @DerekLaw pointed you to, there is a Subscriber tag on that item, it means you must be an authenticated user to access the service. To do this in your app you must supply your API key to the service. You can see an example of this in this Maps SDK for JavaScript example https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=time-layer
--jf
