error: no valid index range
6711
8
01-23-2015 01:34 PM
MariaMaldini
I am trying to add a new field and fill the field for some of rows but I face with the following error:
"The index passed was not within the valid range."
  My simplified codes:
                IMxDocument mxdoc = ArcMap.Application.Document as IMxDocument;
                IMap map = mxdoc.FocusMap;
                ILayer layer = map.Layer[0];
                IFeatureLayer2 featureLayer = layer as IFeatureLayer2;
                IFeatureClass flFeatureClass = featureLayer.FeatureClass;
                IFeatureCursor featureCursor = flFeatureClass.Search(null, true);
                IFeature feature2 = featureCursor.NextFeature();
                IFieldEdit2 newField = new FieldClass();
                newField.Name_2 = "name";
                newField.Editable_2 = true;
                newField.Type_2 = esriFieldType.esriFieldTypeString;
                flFeatureClass.AddField(newField);
                while (feature2 != null)
                    feature2.set_Value(flFeatureClass.FindField("name"), "rome");
                    feature2.Store();
    When i used "breakpoint" to find the error line.  i found out that
  is the line that causes the error (The index passed was not within the valid range).
  I do not know what is wrong with set_value method. when i try to update a already created field, it work right but
  when i want to create a new field and fill it with some data as mentioned codes , i encounter with the error.
Thanks in advance
MariaMaldini
hello guys, there is not anyone who helps me? i could not find any helpful material about this problem on internet. please help me
XanderBakker
Esri Esteemed Contributor
You should first add the field and then start the cursor.
MariaMaldini
if you look carefully you will find out that i created the field before populating it.
MariaMaldini
guys my workspace is  .shp file and i am using ArcGIS 10 with arcinfo license.
XanderBakker
Your featureclass is a shapefile. Your workspace in that case is a folder.
XanderBakker
Create the field: ArcObjects Help for .NET developers
Next use a cursor to update the content of the field: ArcObjects Help for .NET developers :
Make sure you determine the index of the field outside the loop (line 4), to avoid doing this for each feature.
// Use IFeatureClass.Update to populate IFeatureCursor.
IFeatureCursor updateCursor = featureClass.Update(queryFilter, false);
int typeFieldIndex = featureClass.FindField("name");
IFeature feature = null;
try
    while ((feature = updateCursor.NextFeature()) != null)
        feature.set_Value(typeFieldIndex, "rome");
        updateCursor.UpdateFeature(feature);
catch (COMException comExc)
    // Handle any errors that might occur on NextFeature().
// If the cursor is no longer needed, release it.
Marshal.ReleaseComObject(updateCursor);
MariaMaldini
Thanks Xander for your attention,
XanderBakker
... and if you read my answer carefully, you would have noticed that I referred to adding the field before creating the cursor...
