Dynamicmapservicelayer load time
3235
08-12-2015 05:19 PM
DamNguyen
With many layers, the load time is really long when viewed through a web app viewer. If I use this example to generate a map, and have the list of layers unchecked by default, will it minimize load time?
I'm trying to figure out if dynamicamapservicelayer preloads all the layers, or it only fetches a layer when checked using layer.setVisibleLayers(visible);
Thanks for looking.
ChrisSmith7
Honored Contributor
Dam,
I've had luck generalizing geometries (smoothing features by reducing vertices) and using the FeatureLayer class in ON_DEMAND mode:
FeatureLayer (legacy) | API Reference | ArcGIS API for JavaScript
In my case, I had a large number of polygons that needed to display at a large map scale, so scaling wasn't an option.
