Determine the angle between two intersecting lines - Counter-Clockwise direction
8745
08-02-2016 09:33 AM
JoeD
Hey everyone:
I am trying to determine the angle between two intersecting lines. However, I need the angle to be from the start point of line1 to the start- or end-point of line2 - whichever is the next point going in a counter-clockwise direction around the circle's perimeter (see diagram at bottom of question).
My steps so far have been:
1) I found the intersection points and saved them to a point file
2) I created a 10cm buffer around the points (0.1 metres)
3) I clipped line1 and line2 to the buffer
4) I calculated the start- and end-points of line1 and line2 as:
     with arcpy.da.UpdateCursor("line", ('X0a','Y0a','X1a','Y1a', "SHAPE@")) as cursor:
         for row in cursor:
             row[0] = row[4].firstPoint.X
             row[1] = row[4].firstPoint.Y
             row[2] = row[4].lastPoint.X
             row[3] = row[4].lastPoint.Y
             cursor.updateRow(row)
5) I created separate fields and calculated their values as:
     dx = !X1a!-!X0a!
     dy = !Y1a!-!Y0a!
     dxa= !X1b!-!X0b!
     dya= !Y1b!-!Y0b!
     r = math.sqrt(math.pow(!dx!, 2) + math.pow(!dy!, 2))
     ra = math.sqrt(math.pow(!dxa!, 2) + math.pow(!dya!, 2))
     c = math.asin(abs((dxdya - dydxa))/(r*ra)) / math.pi * 180
c is the angle between the points, however, it is not always the angle I need. I need the angle from a point on line1 to the nearest point on line2 going counter-clockwise around the circle's perimeter.
There is probably a really easy  solution for this, but, I just haven't been able to figure it out. Any help is greatly appreciated.
I am using ArcGIS 10.2.
Tags (1)
DarrenWiens2
Forgive me for not wanting to dive back into the tedium of this math, but perhaps you can use something from this thread: Calculating angles using ArcGIS Desktop 10.2
DanPatterson_Retired
a few points on the image or directional arrows to we know where start and end points are
JoeD
Thanks for the response Dan,
I have added points on the image to show where the start- or end-points are. The start- and end-points correspond with where the line feature touches the boundary of the polygon circle. However, in the data, the start- and end-points do not follow a particular pattern or direction.
For my purposes, it doesn't matter if I am comparing a start-point of line1 to an end-point of line2. All that matters is that the point of line1 is being compared to the point of line2 that is first encountered going counter-clockwise around the circle's perimeter.
In the Picture in my edited post I would want to compare the two points with the arrow drawn between them.
