Datum conversion from etrs89 to wgs84
15327
06-25-2015 12:38 AM
RatikantaLenka
i have a chart with etrs89  coordinate system, i want to load the chart into wgs84 vector layer. Any one can help how to do this?
DanPatterson_Retired
Do they both have a defined coordinate system? Define Projection—Help | ArcGIS for Desktop
Is the chart a raster? Project Raster—Help | ArcGIS for Desktop
Have you tried projecting the vector data? Project—Help | ArcGIS for Desktop
have you tried reversing the order of adding them to a new dataframe?
In any event, whatever format they are, they both need to have a defined coordinate system or they have to be projected to a common one
ArnoldKuilman
Transformations between ETRS89 en WGS84 are not straight forward.
Comprehensive explanation: ETRS89 is a European system, fixed to the Eurasian plate, where WGS is an international system (ITRS). Since ETRS89 was realized until today (2012), a difference of 50 to 60 centimeters has accrued between WGS84/ITRS and ETRS89 which continues to grow dynamically at a rate of approximately 2.5 centimeters annually. The difference varies depending upon the location of a given coordinate on the Eurasian plate, because the continent slowly but steadily rotates around the Earth center of mass.
For direct measurements the conversion to or from ETRS89 is usually not necessary, as it in terms of the systemic high inaccuracy of several meters would not lead to a significant improvement. Here, the equating of WGS84 and ETRS89 can be tolerated.
If you have small scale maps where an error or mismatch between 0 till 60 centimetre is no problem, you can leave the coordinates as they are, and consider them as wgs84.
If you have large scale maps, where a high accuracy is necessary you need to take into account the epoch (datestamp) when the data was collected, and you need to find specific transformation parameters for that date.
