Could not load data from data source. If you can correct the problem, press the refresh button to reload data
3556
10-02-2015 08:54 AM
JoseSanchez
Hello everyone,
In ArcMap whenever I start an editing session and try to "Open Attribute Table" I get an error message:
"Could not load data from data source. If you can correct the problem, press the refresh button to reload data. Possible problems can include bad network connection, invaluid field, etc.
Unable to create logfile system tables. User perhaps lacks permission or resources to create tables"
I am working in SDE 10.2 and this happens when I try to edit a feature class that is not versioned.
anyone with a similar issue?
by Anonymous User
Not applicable
Hi Jose,
Here is a Knowledge Base article about a few reasons this could occur:
43077 - Could not load data from data source. If you can correct the problem, press the refresh butt...
Does this help?
