Converting VBScript to Arcade or Python to calculate a field
1714
10-19-2022 06:11 AM
MoniqueWolff
I have the following VB Script expression to calculate a field in a shapefile.
Since ArcGIS pro doesn’t read VB Script for the field calculation, could someone help me converting it to Arcade or Python ?
I unfortunately don’t have the skills for it.
Thanks.
dim X
if len( [INSEE]) =4 then
X = "0" & [INSEE]
Elseif  len( [INSEE])=3 then
X = "00" & [INSEE]
Elseif  len( [INSEE])<3 then
X = "?????"
Else X = [INSEE]
end if
dim N
if len( [PREFIXE])=2 then
N = "0" & [PREFIXE]
Elseif len( [PREFIXE])=1 then
N = "00" & [PREFIXE]
Else N = [PREFIXE]
end if
dim Y
If [SECTFEUI] =" " then
Y="????"
Elseif [SECTFEUI] ="0" then
Y="????"
Elseif len( [SECTFEUI]) =3 then
Y = "0" & [SECTFEUI]
Elseif len( [SECTFEUI]) =2 then
Y = "00" & [SECTFEUI]
Elseif len( [SECTFEUI]) =1 then
Y = "000" & [SECTFEUI]
Else Y = [SECTFEUI]
end if
dim Z
if [PARCELLE] ="0" then
Z="????"
Elseif len( [PARCELLE])=3 then
Z = "0" & [PARCELLE]
Elseif len( [PARCELLE])=2 then
Z = "00" & [PARCELLE]
Elseif len( [PARCELLE]) =1 then
Z = "000" & [PARCELLE]
Else Z = [PARCELLE]
end if
__esri_field_calculator_splitter__
KEY=X&N&Y&Z
Tags (3)
KenBuja
MVP Esteemed Contributor
Are each of your fields numeric? In Arcade, you can use the Text function to pad them with 0.
var X;
var insee = $feature.INSEE;
if (Count(Text(INSEE) < 3) {
  X = '????';
} else {
  X = Text(insee, '00000')
If the fields are strings, then you would have to use this method, using the When function and Template literals
var insee = #feature.INSEE;
var x = When(Count(insee) == 4, `0${insee}`,
              Count(insee) == 3, `00${insee}`,
MoniqueWolff
Thank you very much for your answer.
Some of my fields are numeric and some of them are strings.
I finally managed to do it using Python 3 like this :
def concatspecial(INSEE,PREFIXE,SECTFEUI,PARCELLE):
if len(str(INSEE))==4:
x = "0"+INSEE
elif len(str(INSEE))==3:
x = "00"+INSEE
elif len(str(INSEE))<3:
x="?????"
else:
x=INSEE
if len(str(PREFIXE))==2:
n="0"+str(PREFIXE)
elif len(str(PREFIXE))==1:
n="00"+str(PREFIXE)
else:
n=PREFIXE
if SECTFEUI==" ":
y = "????"
elif SECTFEUI=="0":
y="????"
elif len(SECTFEUI)==3:
y="0"+SECTFEUI
elif len(SECTFEUI)==2:
y="00"+SECTFEUI
elif len(SECTFEUI)==1:
y ="000"+SECTFEUI
else:
y = SECTFEUI
if PARCELLE=="0":
z="????"
elif len(str(PARCELLE))==3:
z = "0"+str(PARCELLE)
elif len(str(PARCELLE))==2:
z = "00"+str(PARCELLE)
elif len(str(PARCELLE))==1 :
z = "000" + str(PARCELLE)
else:
z = PARCELLE
return str(x)+str(n)+str(y)+str(z)
Have a good day !
