Con tool is not working arcgis 10.5
2049
04-18-2018 10:21 PM
Md__OsmanSheikh
I have a raster dataset [Flow Accumulation  Raster]. Which is located in a gdb. I need to perform Con Tool operation with this raster dataset. The Con Tool operation run successfully in ArcGIS 10.1,10.2,10.3 and 10.4 but it does not work in 10.5 .
Can anyone help in this regard?
DanPatterson_Retired
Perhaps if you provide the Con syntax and full filenames and paths that you are using in the tool
Md__OsmanSheikh
Thank you , for your reply. Con syntax , filenames and paths used same in all version . Except ArcGIS 10.5 all are working fine.
that is good, but things might have changed in 10.5 so it would be hard to assess what has worked against some unforeseen difference or an error.
In any event, if things don't work in 10.5, you might as well move on to 10.6.*.  If it works there, then the problem is isolated to 10.5, if it doesn't, then the changes need to be assessed
You should also move this thread to the https://community.esri.com/community/gis/analysis/spatial-analyst?sr=search&searchId=4af83fe5-871f-4...‌ since it has little to do with the Developer place
