Campus place locator
6026
6
12-10-2015 08:26 AM
BrianLomas
I've been working with the Campus place locator template and I was just wondering if using the "internet information services manger" is the only way to convert it to an application to place it on our server? The instructions for the template only gives that as a method. I do not have access to that on my computer.
Link to publishing template information... Publish application - Campus Place Locator | ArcGIS for Local Government
Thanks for the help.
RickeyFight
What I did was copy in the folder for campus place locator and then browsed to the location.
You should be able to do the same on your windows server. Copy the folder to the same root as the other apps.
RickeyFight
Brian,
Do you have a folder on IIS where you have other html or scripts that you can access on the web?
BrianLomas
I have never used IIS and as far as I'm aware we don't use it. We do have several apps on a windows server.
RickeyFight
BrianLomas
I did try that but when I try to open the application it just opens an empty browser.
RickeyFight
Can you post the link?
BrianLomas
I got it to work. I was not entering the server address correctly. Thanks for your help and patience on this I'm new to using/configuring application templates.
