arcpy SelectByAttribute_management
1461
04-30-2020 08:46 AM
FakherRouatbi
hi, i try to add a point xy to feature class and i want to select the latest record in table (recently added). The script runs and I don't have any error message but the tool doesn't select any thing. How can I fix this?
import arcpy
arcpy.env.workspace = r'D:\Geodatabases\BD_VOCATION.gdb '
points = r'D:\Geodatabases\BD_VOCATION.gdb\Loc_vocation'
try:
    arcpy.MakeFeatureLayer_management(points,'points_layer')
    rows = arcpy.SearchCursor(points,'','',"OBJECTID", "OBJECTID D")
    lst = []    for row in rows:
    m = row.getValue("OBJECTID")
    lst.append(m)
    v = lst[0]
    r= str(v)
    query = """{0} = {1}""".format(arcpy.AddFieldDelimiters(points, "OBJECTID"), int(r))
    arcpy.SelectLayerByAttribute_management("points_layer", "NEW_SELECTION", query)
except:
    print "An error occured during selection"
JoeBorgione
perhaps you could paste your code into a python syntax highlighter window so we can see it easier....
That should just about do it....
JoeBorgione
import arcpy
try:
    lst = []
    for row in rows:
        lst.append(m)
        v = lst[0]
        r = str(v)
except:
This is what I meant for formatting.  I indented the best I could but since I don't understand your logic Lines 13 and 14 may not be part of the for loop.  However, that said, a few things jump out:
You should be using da.SearchCursor; I don't know if the original SearchCursor works any more.
You are mixing and matching between your feature class and your feature layer.
The syntax in line 6 even for the old search cursor isn't correct. I suggest you use the more 'traditional' syntax to a search cursor as shown in the help pages.Can you explain your logic in lines 9 through 12?
Finally, what is your end game?  That is, what are you trying to accomplish?
