arcpy.Append_management throws exception
684
11-05-2019 05:02 AM
leonoestergaard
My mission is to add this specific point (
arcpy.Point(495880.110399999666220115.4076000005,-99)
to a feature class, the fc are a part of a geometric network
I cannot use the arcpy.da.insert cursor due to Bug NIM102778
So first i create a new feature class which is not a part of a geometric network like this:
spatial_ref = arcpy.Describe("ELDB.EL.MUFFE").spatialReference    fc = arcpy.CreateFeatureclass_management(r"C:\Connections\GISProddb\Schema\E[email protected]\ELDB.EL.El""MyTempFeatureClass",  "Point","ELDB.EL.MUFFE",None,"ENABLED",spatial_ref)
 And inserts into the new class like this
point2 = arcpy.Point(495880.110399999666220115.4076000005,-99)
pt2= arcpy.PointGeometry(point2,spatial_ref)
icursor = arcpy.da.InsertCursor(fc,["SHAPE@","SNCode","RMCode","LCCode","OMCode","Enabled","MACode","ADate","Comment"])
icursor.insertRow([pt2,"10000",0,1,0,1,3,datetime.datetime.now(),"Created from TestScript"])
del icursor
At this point Im able to find the MyTempFeatureClass and the inserted point in ArcMap
Now its time to append the point into thw feature class in the geometric network
Im doing it like this
edit = arcpy.da.Editor(r"C:\Connections\GISProddb\Schema\E[email protected]")
edit.startEditing(FalseTrue)
edit.startOperation()
try:
    arcpy.Append_management (r"C:\Connections\GISProddb\osa\E[email protected]\ELDB.EL.MyTempFeatureClass"r"C:\Connections\GISProddb\osa\E[email protected]\ELDB.EL.MUFFE",'NO_TEST')
except Exception as e:
    pass
finally:
    edit.stopOperation()
    edit.stopEditing(True)
The exception is:
ERROR 000372: Spatial Reference for output is invalid, Please update to allow output to become valid\nFailed to
execute (Append).\n'
Any ideas on what is happening?
