ArcMap crashes when inserting new feature into file geodatabase
1302
07-25-2016 09:34 AM
LimingWu
New Contributor II
Hello,
What I'm doing is really straight forward. In my Add-In extension, I simply create a new file geodatabase and a new feature class, and insert point features for a list of lat/longs using feature buffer. However, ArcMap creashes right on featureCursor.InsertFeature(featureBuffer). I'm using ArcMap 10.4.1. Any idea would be greatly appreciated.
       private void AddNewTrackingPoints(IFeatureClass featureClass, List<TrackingRecord> trackingRecords)
            IDataset dataset = (IDataset)featureClass;
            IWorkspace workspace = dataset.Workspace;
            IWorkspaceEdit workspaceEdit = (IWorkspaceEdit)workspace;
            workspaceEdit.StartEditing(false);
            workspaceEdit.StartEditOperation();
            // Create the feature buffer.
             IFeatureBuffer featureBuffer = featureClass.CreateFeatureBuffer();
            // Create insert feature cursor using buffering.
            IFeatureCursor featureCursor = featureClass.Insert(true);
            try
                foreach (TrackingRecord record in trackingRecords)
                    Point p = new PointClass();
                    p.PutCoords(record.Longitude, record.Latitude);
                    // Set the feature buffer's shape and insert it.
                    featureBuffer.Shape = p;
                    System.Reflection.PropertyInfo[] props = record.GetType().GetProperties();
                    foreach (System.Reflection.PropertyInfo prop in props)
                        int fieldIndex = featureClass.FindField(prop.Name);
                        featureBuffer.set_Value(fieldIndex, prop.GetValue(record));
                   featureCursor.InsertFeature(featureBuffer);  //ArcMap creashes here
                // Attempt to flush the buffer.
                 featureCursor.Flush();
            catch (COMException comExc)
                // Handle the error in a way appropriate to your application.
            finally
                // Release the cursor as it's no longer needed.
                  Marshal.ReleaseComObject(featureCursor);
            workspaceEdit.StopEditOperation();
            workspaceEdit.StopEditing(true);
Tags (1)
LimingWu
New Contributor II
Turns out is a threading issue. The method is called by a timer method. Calling it from a extension's method fixed the problem.
LimingWu
New Contributor II
Could it be license issue? I'm using ESRI's home program.
LimingWu
New Contributor II
