ArcGIS Pro Spatial Reference
5882
02-09-2016 06:04 PM
RogerLoweth
I can't figure out how to get the equivalent of this arcpy.mapping code into arcpy.mp
# Set the CRS values based on the current data frame CRS
    # get the map document
    mxd = arcpy.mapping.MapDocument("CURRENT")
    # get the data frame
    df = arcpy.mapping.ListDataFrames(mxd)[0]
    sr = df.spatialReference
Can anyone help please?
Tags (1)
DanPatterson_Retired
from the help topic
get the current document
get the first dataframe called "yosemite national park"
get a list of the layers
do stuff with the layer IF it supports showlabels
p = arcpy.mp.ArcGISProject("CURRENT")
m = p.listMaps("Yosemite National Park")[0]
for lyr in m.listLayers():
    if lyr.supports("SHOWLABELS"):
        lblClasses = lyr.listLabelClasses()
yours
get the current project
get the first dataframe called Map
try to get its spatial reference which... it works... will just return a spatial reference object and not its name
so even if that works you might want m.spatialReference.name (check spelling is it S or small s in spatialReference)
So see
Introduction to arcpy.mp—ArcPy | ArcGIS for Desktop  and
Map—ArcPy | ArcGIS for Desktop
but here is the only place you are going to get the SR
SpatialReference—ArcPy Classes | ArcGIS for Desktop  since the map and map frame apparently don't have any concept of SR that I can find...however, I haven't fully explored all, and all hasn't been ported yet
Roger... have you seen the migration documentation ? ... Migrating from arcpy.mapping to ArcGIS Pro—ArcPy | ArcGIS for Desktop
RogerLoweth
Dan - yes, I'm looking at it now. I can see how to do it by referencing a layer, but what if I don't have any layers when I invoke my tool?
RogerLoweth
I tried doing this, but it doesn't work:
    m = p.listMaps("Map")[0]
    sr = m.spatialReference
from the help topic
yours
So see
RogerLoweth
Thanks Dan - that's what I thought; map and map frame don't seem to have any concept of spatial reference, even though from the help:
"A Map in ArcGIS Pro represents a collection of  tabular and symbolized geographic layers and also persists information like coordinate system, default views of the data, and various other metadata."
So clearly the map works with the CRS - it just doesn't allow the poor old user access to it!
Maybe in the next version...
Cheers, Roger
