Arcade: multiple values in an array (arrays in an array).
2669
02-11-2021 08:38 AM
TL2
This script adds a number of rows to a table on insert of another table.  It uses an array to updated a field value when these rows are entered.  I would like to enter multiple field values instead of just one, which works as seen below.  My first script is what works with one value, using a simple array.  My second script is what I am trying to accomplish but I am not sure how to format my row.
var rowid = $feature.uniquerowid
var myArray = ['value1','value2','value3']
var counter = 0
if(IsEmpty($feature.inspect_date)){
for (var os in myArray){
myArray[counter] =
       "attributes": {
             "parentrowid": rowid,
             "q_2control": myArray[os],
             "number": counter
                        counter++
   return {
"result": rowid,
"edit": [{
    "className": "featureClass",
    "adds": myArray
else {
return rowid
I would like to enter multiple fields for each row added.  Something like this:
var myArray = [['value1A,'value1B'],['value2A,'value2B'],['value3A,'value3B']]
var counter = 0
myArray[counter] =
       "attributes": {
             "q_2control": myArray[os[a]],
             "choice": myArray[os[b]]
             "number": counter
                        counter++
   return {
"result": rowid,
"edit": [{
    "adds": myArray
else {
return rowid
@XanderBakker
You can see above in my add statement I am updating two fields on each row...or trying to.
XanderBakker
Esri Esteemed Contributor
Hi @TL2 ,
Since you don't have a variable a and b, the code will fail. You can use the indexes (0 and 1) to extract the "a" and "b" values:
             "q_2control": myArray[os][0],
             "choice": myArray[os][1]
XanderBakker
Hi @TL2 ,
