Arcade labeling to return the characters before a dash.
4472
05-18-2023 02:30 PM
IsaiasSegovia1
I'm trying to create an arcade expression to return all the characters before a dash. The field contains these values:
PE - Polyethylene
STL - Steel
AA - DuPont Aladyl-A
TR-418
I thought that this arcade code would help to label the line feature:
Trim(Left(DomainName($feature, 'MATERIAL'),3))
It help solve the issue with the steel, but this was no help since the TR-418 does not have a space between the R and dash, and it return "TR-".
Any ideas now how I can create this arcade code to label the line without the dash.
KenBuja
MVP Esteemed Contributor
You can use Split to divide it at the dash and take the First value from that array
Trim(First(Split(DomainName($feature, 'MATERIAL'),'-')));
KenBuja
IsaiasSegovia1
It worked, thank you so much.
