Arcade expressions in Collector?
8967
16
12-16-2016 09:38 AM
Trippetoe
Hello.
Are Arcade expressions recognized in Collector?  I have generated a test map in AGOL and based the symbology on an Arcade expression. It works fine in AGOL, but the same map seems to crash in Collector.
Thank you.
FrankPotempa
Now that the new Collector is released for iOS do we see support for Arcade expressions? We are looking to use in Collector with auto increment or calculating values based on input is available.
Sveinung_Bertnes_Råheim
We tried to test arcade driven symbology in the new version of collector for IOS (18.10) today. The symbology worked fine in webmaps and webapps, but it did not work i Collector. The features simply disappeared.
Obviously, there is still a way to go for ESRI.
HuongTran1
Sveinung Raheim‌ i have tried my map that has an arcade expression in my android phone and it is showing properly. The only problem now is i think relate it still not working.
That must be in a webapp? Because ESRI says that the existing Version of collector is not supporting Arcade. But it will be (at some point) supported in the aurora-Version of colletor, supposed to be released in first half of 2019.
HuongTran1
Oh sorry yeah i tested it in the collector aurora beta version.
MarkBockenhauer
Arcade expressions can be used to show information in a custom popup configuration.   The ability to show layer symbols based on an Arcade Expression in Esri Apps (Built on ArcGIS Runtime) is still being worked on for a future release.
Mark
HuongTran1
We are trying to show inspection due this month and the previous 2 months by using the Now() function I was able to have it work fine in AGOL but Collector is not display the same as in the webmap.
