Api Key issues
5572
10
06-27-2025 11:31 AM
DeanWilson
I was going through this particular tutorial:
https://developers.arcgis.com/calcite-design-system/tutorials/create-a-mapping-app/
And it's got the information about using api keys.  I built an api key for my test app (using vite) and after I setup the information to allow use of my enterprise portal (which is on version 11.4) and using 4.33 api, it's still prompting me for a login, even though I've selected the items in the webmap that I'm using the key to authenticate for.  Here's my current page code (remember this is to test api key authentication):
<!doctype html>
<html lang="en">
  <head>
    <meta charset="UTF-8" />
    <link rel="icon" type="image/svg+xml" href="/vite.svg" />
    <meta name="viewport" content="width=device-width, initial-scale=1.0" />
    <title>Calcite Web Map</title>
    <script src="https://js.arcgis.com/calcite-components/3.2.1/calcite.esm.js" type="module"></script>
    <script src="https://js.arcgis.com/4.33/"></script>
    <link rel="stylesheet" href="https://js.arcgis.com/4.33/esri/themes/light/main.css" />
    <script type="module">
      const esriConfig = await $arcgis.import('@arcgis/core/config.js')
      esriConfig.portalUrl = '<my enterprise portal>'
      esriConfig.apiKey = '<my api key>'
    </script>
    <script type="module" src="https://js.arcgis.com/4.33/map-components"></script>
  </head>
  <style>
    html,
    body,
    #webMap {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      display: flex;
    </style>
  <body>
    <arcgis-map id="webMap" item-id="4f48ecb117874273a5f3a8bdc4d440f5">
      <arcgis-zoom position="top-right"></arcgis-zoom>
    </arcgis-map>
  </body>
</html>
Thoughts?  I've been dealing with this all day and have been waiting for api keys to be available to enterprise users for authentication purposes for a while now.
Thanks!
Dean Wilson
AndersonYanez
Hi @DeanWilson , I am having the same issue using ArcGIS Enterprise Portal. I tried to follow all suggested comments, but it's still prompting me for a login. How did you make it works?
