Another SDE Feature Classes needing repairs question
1673
10-14-2016 11:26 AM
CostasKotzabassis
Apart from the ESRI declared...position that the SDE is self-correcting itself, does anybody know how to repair the Features in the SDE Feature Classes with the problems listed in the Check Geometry tool, particularly self-intersecting polygons? Need to automate the process through a Python script and clearly the Repair Geometry does not work either on the SDE data sources. Repairing the Features off-line still leaves the task to go back to replace them in the versioned Featured Class. Any bright ideas would be greatly appreciated. Thank you.
JakeSkinner
Esri Esteemed Contributor
Hi Costas,
You could create a geodatabase topology with the rule that the polygons must not self-intersect.
