Add a table to a Map Series tab
2144
07-26-2016 09:26 AM
SarojThapa1
I have an app created using map series in arcgis online. In one of the tabs, I want to add a table. The table is in excel file. What I want to do is: when the tab is clicked, it points to an URL and the URL refers to the table. What could be the most convenient way to do so?
Thanks!
AdrianWelsh
MVP Honored Contributor
Saroj,
Could you put the table in something like Google Drive and share it publicly? Then link to the table? You can also make it a Google Sheet and link to the sheet to where it is somewhat interactive. I suspect a Google Sheet will behave better in web-like environment than an Excel sheet.
Tagging Story Maps
SarojThapa1
I thought about hosting in google drive, but I don't want to share the table publicly. I will see if I can use google sheet. Thanks Adrian
AdrianWelsh
Saroj,
Google Drive gives many options for how the file is shared (I wish ArcGIS Online had similar options). You can share it publicly, share it by only people with access to the link, share it with individual email addresses, share it within a group, etc. The options do not stop there.
Share files and folders - Computer - Drive Help
