About "esri/tasks/query"  's question
5614
02-22-2015 03:57 AM
zhongrenGu
my codes:
in chorom:
Now  I confused,  my god  ,what happend??
they are the same in  local/web api !
RobertScheitlin__GISP
Zhongren,
  Is there a reason that you are not using a local variable for query and queryTask in your initData function? Why would you want it to be scoped to the whole widget source by using 'this.' ? Your overall issue is a scope problem. Inside the execute block the scope of 'this' is not the same as it was before.
initData: function () {
  var query = new Query();
  query.outFields = [this.config.queryFields];
  query.outSpatialReference = this.map.spatialReference;
  query.where = this.config.queryWhere;
  var queryTask = new QueryTask(this.config.queryTaskUrl);
  queryTask.execute(query,
      lang.hitch(this, function (featureSet) {
        console.log(featureSet);
      lang.hitch(this, function (error) {
        console.log(error);
zhongrenGu
Robert Scheitlin, GISPDan Patterson
thank you very much!!
FilipKrál
Hi, not sure what's going on there but can it be because of a typo where you are creating the new QueryTask?
`this.config.qeuryTaskUrl` vs. `this.config.queryTaskUrl`, swap the 'eu'?
zhongrenGu
Not  this  reason, i check every words , but   thank you very much  !
Zhongren,
        console.log(error);
zhongrenGu
Thank you very much!    good  night!
