2 fields symbology ArcGIS Online Map/Appli
5716
03-03-2016 08:47 AM
TimothéeColas
Is it possible to do a symbology with 2 text-fields in a ArcGis online Map? to use it in an appli.
I fount how to use one text-field or one text field and a numeric one, but i didn't find an option for multi-text-fields symbology.
AdrianWelsh
MVP Honored Contributor
It does not look like it is possible to do this with ArcGIS Online web maps. You would have to configure this on the publishing end in ArcMap to concatenate your values or some other creative way of squeezing multiple attributes into one field.
Your options for symbolizing in ArcGIS Online are:
  • 1 text field
  • 1 text field and 1 numeric field
  • 1 to 5 numeric fields
TimothéeColas
Ok.
I have to find if it's possible to automatically concatenate fields.
Or the other solution is to attribute numeric code for each text value, and then use a two numeric fields symbology.
I want to create a web app that my colleagues can update out of office, and see progress with symbology. 2 factors are necessary to valid an action.
AdrianWelsh
You can't really concatenate fields in ArcGIS Online, unfortunately. This will need to happen at the desktop level, likely. It may work for you to use one of your text fields as a number field in order to symbolize it the way you want in AGOL.
