10.5 - Feature Class To Feature Class Field Mapping, Double Scale and Precision
1299
04-13-2017 09:14 AM
BarryLariviere
Hello.
I have run into an issue with setting the scale and precision on a double field and it holding.
I had built several models in 9.3 that would take a layer form a personal database and export to a shapefile, with specific field names and field sizes. Specifically several double fields that were set to 3 and 2 on scale and precision. In 9.3 they worked perfectly. Now in 10.5 when I set the same values for the double fields as I had in 9.3, the numbers returned are the same as they were in the personal database. Has anyone else had this issue? Any resolutions? For now I am running things through 9.3, but would like to resolve to hand off to other users using 10.5.
DanPatterson_Retired
A bug was noted in 10.4... check this thread... the bug number can be tracked to see if has been resolved
BarryLariviere
Thanks Dan
