Developers Ideas
Developers Ideas
Other Boards in This Place
Latest Activity (382 Idea Submissions)
Sort/Filter :
Under Consideration
Hi Esri,Nearly all SDKs have their own board in the "Developers" board. However, the "Enterprise SDK" does not.Curren...
RalfSchmidt
by RalfSchmidt Regular Contributor
in Developers Ideas Last Updated 03-17-2023
0 1
Under Consideration
On the ArcGIS Developers site, you can click the View Usage button on any Geocoding API you have created. For the tim...
DavidWittmann
by DavidWittmann Regular Contributor
in Developers Ideas Last Updated 03-20-2023
0 1
Under Consideration
When creating a 3D dataset as an SLPK we want to be able to update components of the SLPK for example an SLPK may con...
SkyePaxton
by SkyePaxton Emerging Contributor
in Developers Ideas Last Updated 07-06-2022
4 5
Under Consideration
I'm working on a PWA with Web assembly that requires our server to be in a Cross Origin Isolated state.  This is rela...
JonMullen
by JonMullen Emerging Contributor
in Developers Ideas Last Updated 11-24-2021
1 1
Under Consideration
I propose that configurable usage alarms be provided for each API key that is created in the Developer's dashboard. A...
AndrewVitale
by AndrewVitale Occasional Contributor
in Developers Ideas Last Updated 05-31-2022
9 3
9
Under Consideration
Currently the deprecation item flag is mostly useless. It can be a deterrent from new users picking a service but the...
stevegourley
by stevegourley Frequent Contributor
in Developers Ideas Last Updated 09-14-2020
9 2
9
Under Consideration
Flutter is a new framework by Google for cross platform development on Mobiles. ArcGIS SDK for Flutter and examples a...
MirHashmi
by MirHashmi Frequent Contributor
in Developers Ideas Last Updated 01-25-2024
33 30
33
30
Under Consideration
I think that when an item is created from an existing feature layer:# Create a new empty comment layer from the alrea...
ZacharyNeumann1
by ZacharyNeumann1 Occasional Contributor
in Developers Ideas Last Updated 03-07-2017
3 0
Under Consideration
At the moment using the steps below doesn't add a link as expected.The embedded link only works if the option below i...
GISSection
by GISSection Occasional Contributor
in Developers Ideas Last Updated 02-03-2015
2 0
Under Consideration
Allow publisher to add a table of contents section so users may be able to internally navigate through the journal "p...
HenryHansen1
by HenryHansen1 Deactivated User
in Developers Ideas Last Updated 07-31-2015
7 1
7
Under Consideration
I like the layout of the ArcGIS Online Map Tour web application, but would prefer the caption text be placed under th...
SheriNorton
by SheriNorton Frequent Contributor
in Developers Ideas Last Updated 11-19-2015
2 1
Under Consideration
Most of the time i work with either ArcGIS API for FLex or Javascript. Its part of my work to create graphics layer f...
ZahidChaudhry
by ZahidChaudhry Deactivated User
in Developers Ideas Last Updated 01-29-2013
27 1
27
Under Consideration
 WPF, Silverlight Out-of-Browser, and Windows Phone 7 all have the ability to work in a disconnected/offline mode sin...
EricDaniel
by EricDaniel Deactivated User
in Developers Ideas Last Updated 04-18-2012
64 14
64
14
Under Consideration
Saw silverlight API at Dev conference, so this request for core (out-of-the-box) components is based on the templates...
JTessier
by JTessier Frequent Contributor
in Developers Ideas Last Updated 08-31-2011
100 6
100
6
150 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
Suggest an idea
Top Kudoed Ideas (last 30 days)
Top Kudoed Authors
