Flex API: Print to PDF - Scale Units
1467
11-19-2012 08:03 AM
Status: Open
MarkYandrick
In the Flex API, no matter the units defined in your map service, the print to PDF widget only allows users to print at the 'map units' scale and not at desired units, such as feet, meters, miles, etc.   The option for the end user when printing to PDF (or other image) to see or choose which map units are being referenced would be a wonderful addition we can pass along.
 0EME0000000TU1W
4 Comments
KenCarrier
I think it would be good if the scale could be derived from the data frame properties that it was created from. For example if we set the dataframe properties to be 1in=100 feet, then it would come across in the service itself or the widget. The other option is allow us to specify how we want the scale derived when setting up the geoprocessing service. I really like the new print service, with a couple more tweaks from Esri I think it will be perfect!
AndrewAidt2
I would like this functionality in the Silverlight Viewer as well!
MatejFetih
This functionality would be required also in Javascript API!
fatizanady
hi everyone,
i would like to download this widget any link plz??
