Hello I'm B. Morris. Not sure if this is the right place being new to the GeoNet, but figured I would try. I'm using ArcGIS for desktop V10.5.1. I need some quick advice on how to make something work due to a time critical mission I am working. Here is the deal: I wish I could show the table I took a screen shot of. 1. Attribute table named "Building_Clean_up" 2. In the attribute table there are two data columns named "Building_I" and "FAC_NUM". Question is this: How do I copy the data from the "Building_I" data column over to the "FAC_NUM" data column? I have tried everything that I know of thus testing what little knowledge I have. Can someone help expand my 10% factor here? LOL Vr... Brook M.
Thanks for the quick reply. What syntax do I utilize to simply copy it over from one column to the other within the field calc?
Building_I is a text field... is Fac_num also? if so make the Fac_num field selected, right-clidk, Field Calculator, then... using the python parser and for the calculation it would be !Building_I! note the ! marks.
If the Fac_num isn't a text/string field, all bets are off
My bad, yes they are both text fields (strings)
the syntax is in my example... python.... !Building_I!
Dan, You just made my day along with my bosses. Much appreciated!
