Using data pipelines to load data from one feature layer into another feature layer with a different schema. Is this possible?
688
08-02-2024 01:49 PM
Labels (3)
MDB_GIS
I've been experimenting with data pipelines a bit and hit a bit of barrier. I have an AGOL feature class that one of our consultants is using to collect data. They are using their own established schema that works well for us. But I would like to deploy an ESRI Solution that can utilize that data. The feature class our contractor has contains all of the fields required for the solution but they are just named differently. I would like to set up a pipeline to map the schema from our contractor data to the solution feature class on a regular basis. Is this possible?
I've tried using the "Map fields" tool, but I always end up getting an error message at the end that says the tool is not compatible with that layer.
