I've attempted to create a connection to a Data Store using the BETA Data Pipelines in ArcGIS Online. The data store is Snowflake. On every occasion I insert the requirement parameters,
Server
Username/Password
Database
Schema
Warehouse
Role
I've confirmed outside of AGOL that the credentials and parameters work and connetion is successful.
however, in AGOL I continue to get 'Validation Failed"
Any ideas? Is there a specific driver I need?
Hi Jennifer,
Is your Snowflake connection only accessible from an internal network, and not from an external service like ArcGIS Online? Are the other apps you are using running within your network?
This is one idea. I also have a few more ideas to investigate if you'd like to follow up over email, my email is mpayson@esri.com
Thank you for trying the beta and posting your issue!
Max
Thanks Max, I will follow up with you via email
Hi Jennifer.
I had the same error.
when you set up the connection, on the server parameter, you must write it whitout the https. for example if it "https:/<idaccount>.snowflakecomputing.com" is you url you must put <idaccount>.snowflakecomputing.com
I am able to establish the connection to snowflake but cannot view any tables that I can access via the browser. Any ideas as to why?
If we have to connect to table before we can add the connection, why don't you ask for table name in the Snowflake Connection configuration?
