Why there is no primary key for tables
6470
7
01-21-2018 09:46 PM
ModyBuchbinder
In Sql Server when I create a layer the OBJECTID is defined as primary key.
When I create a table (using ArcMap) the OBJECTID is not define as primary key.
See the screen shot, AAA is a layer (have a shape filed), BBB is a table.
Any reason for this?
Thanks
Mody
shan_sarkar
Mody,
Is BBB table is a non-spatial table?
~Shan
~Shan
ModyBuchbinder
Yes I just did right click on the database connection and select  New->Table
Asrujit_SenGupta
There is a Unique Key created in case of Tables:
ModyBuchbinder
Index is not the same as primary key
See the key icon next to the OBJECTID field that exists in TESTFC and does not exists in TESTTABLE
Asrujit_SenGupta
What is an ObjectID?—Help | ArcGIS Desktop
An ObjectID is a unique, not null integer field used to uniquely identify rows in tables in a geodatabase. ObjectIDs are limited to 32-bit values, which store a maximum value of 2,147,483,647.
So this satisfies the requirement for an ObjectID atleast.
Yes, they may not be the same and hence the question could be "Why does ArcGIS create a Primary Key in case of Feature Classes, but a Unique Index in case of Geodatabase Tables?"
Asrujit_SenGupta
From a quick test, it seems the behaviour is not same in an Oracle Enterprise gdb.
A Feature Class created in an Oracle sde gdb, does not have the ObjectID as a Primary Key.
FredSpataro
I just ran into this issue... oddly it appears to be different if the database is 'geodatabase enabled' or not ... at least on SQL Server.  I just created a table via ArcCatalog on a plain/non-geodatabase database connection and the OBJECTID column is set as the primary key by default.
