Visual specification
1227
09-04-2013 09:40 PM
HitomiMaezawa1
Hello everyone,
I was wondering if anyone is familiar with using visual specification in Production Symbology tool bar.
I am trying to create a set of symbology using Visual Specifications,
and apply that to another map which has same field names since I use SQL statement to set symbology.
According to help, I just have to import the visual specifications that I have already created for another map,
but it does not get reflcted in new map even though the specification IS imported since I can see them under
"Calculated Representations" tab.
Strangely, if I edit something in specifications and apply it, all the symbology get reflected and solves the problem,
but I would like to get it reflected without doing anything.
Does anyone have an idea?
Anything will be my help, thanks in advance!
WilliamMortimer
Hi Hitomi,
2 things could be happening - The first time you run the visual spec tool - It should create 3 new fields on your dataset -
  • Rule ID
  • Rule ID overide
  • Blob
if these fields are created but show <null> values you will either need to force the vst to apply by using 'field calc' command, running the toolbox function - or what you are doing via the edit > update etc. Its described here in detail
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
There is also a check box somewhere (calc fields tab down the bottom of the dialog?) that refers to update. Try toggling this. This halts the update because otherwise your specs might recalculate after 1 edit etc.
The easiest way to see if your visual spec has not been applied correctly is that you will get 'red - unplaced' symbology for features are missing or the rules dont match. There is also a arctoolbox fuction that can find those elements as well.
Hope this helped in some way,
William
