Vertex Counts by Feature
2194
11-27-2018 08:49 AM
SueBurnett
Is there a way to determine the number of vertices in a feature?
If so, can the number be displayed in the attribute table?
JakeSkinner
Esri Esteemed Contributor
Hi Sue,
You can execute the Add Geometry Attributes tool with the option POINT_COUNT checked.
JakeSkinner
Hi Sue,
SueBurnett
Thank you Jake – this is very helpful!
JoshuaBixby
You can also create a field to hold the count, and then use !Shape!.pointCount with the Python parser with the Field Calculator.
SueBurnett
Thank you Joshua – this is very helpful!
