I'm in ArcMap, viewing the attribute table for a point feature class...
'0 out of *2000 Selected'... Why has it put this limit on the attribute table? There should be 25,000 ish records.
On the map itself, 25,000 points do display/draw however.
I do have a definition query but this should exclude around about 500 records only..
This issue only occurs with File Geodatabase feature classes. Sourced to a shapefile copy of the dataset, this issue doesn't happen.
What's going on? Lot's of questions I've had recently!
ArcGIS Desktop 10.4
