Unregister replica and delete version
5967
06-27-2014 07:01 AM
RobBlash
I have a check out replica that was not used, so I'm trying to clean up my versions and get rid of the replica version. I'm using SDE personal w/ SQL Express. I have several versions and each version is periodically checked out for editing.
Assume I have VersionA which is checked out as Replica1. What is a good workflow to get rid of replica1 if no edits are made? I can go to version manager and delete replica1 then go to manage replicas and unregister  replica1. Does my order of operations make a difference here? I know I can just check in a database with no edits and achieve the desired results but that seems to be the long way around the issue.
What exactly does unregistering a replica mean? Can't seem to find this in the help.
Thanks!
AsrujitSengupta
Check: http://webhelp.esri.com/arcgisserver/9.3/java/index.htm#geodatabases/managing_replicas.htm
By right-clicking an individual replica, you bring up a context menu with the following options:
  • Rename???Renames the replica. Enter a new name and press Enter.
  • Unregister???Unregisters the replica. If a synchronization version exists, it will also be removed at the same time.
  • View log???Opens up the replica log. This option is only available for one-way and two-way replicas. The replica log is discussed in more detail below.
  • Refresh???Refreshes the replica. The latest state of the replica properties will be displayed.
  • Validate schema???Validates the replica schema. A progress bar monitors the status of the validation. This automatically corrects a replica that contains invalid datasets. Datasets can become invalid if they have been renamed, deleted, or unversioned.
  • Properties???Opens up the Replica Properties dialog box. Replica properties are discussed in more detail below.
AsrujitSengupta
Unregistering a replica---> equivalent to Deleting that replica from that geodatabase
Go to Replica Manager and unregister that replica...don't change anything in Version Manager/Versions table...
AsrujitSengupta
RobBlash
Thanks for the info. Is there any reson behind not doing anything in the version table?
AsrujitSengupta
As I highlighted in my last post :
Unregister�??Unregisters the replica. If a synchronization version exists, it will also be removed at the same time.
That version will automatically be removed during the "Unregister' process.
